Ga door naar hoofdinhoud
Audio-Technica LP60XBT Turntable Gear Replacement
Wat je nodig hebt
  1. Audio-Technica LP60XBT Turntable Gear Replacement, Gear: stap 1, afbeelding 1 van 2 Audio-Technica LP60XBT Turntable Gear Replacement, Gear: stap 1, afbeelding 2 van 2
    • Remove the felt pad, and put it to the side.
  2. Audio-Technica LP60XBT Turntable Gear Replacement: stap 2, afbeelding 1 van 1
    • Turn the platter so that the brass motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Audio-Technica LP60XBT Turntable Gear Replacement: stap 3, afbeelding 1 van 2 Audio-Technica LP60XBT Turntable Gear Replacement: stap 3, afbeelding 2 van 2
    • Remove the platter by grasping the platter by its two inner holes and lifting it upwards.
    • If the drive belt is unhooked and the tone arm is safely to the side, don’t be afraid to use a small amount of force in lifting the platter if necessary.
  4. Audio-Technica LP60XBT Turntable Gear Replacement: stap 4, afbeelding 1 van 1
    • Remove the four screws holding in the gears using a Phillips #0 screwdriver.
  5. Audio-Technica LP60XBT Turntable Gear Replacement: stap 5, afbeelding 1 van 3 Audio-Technica LP60XBT Turntable Gear Replacement: stap 5, afbeelding 2 van 3 Audio-Technica LP60XBT Turntable Gear Replacement: stap 5, afbeelding 3 van 3
    • Remove the large white gear by pulling it upwards.
    • Remove the small white gear and base by pulling them upwards.
  6. Audio-Technica LP60XBT Turntable Gear Replacement: stap 6, afbeelding 1 van 1
    • Insert the small replacement gear first, then the large replacement gear second.
    • When replacing the smaller gear and base, be sure to feed the black ground wire through the hole in the base.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Devon Ferreira
238 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 61
Altijd: 2,178
