Ga door naar hoofdinhoud
Audio Technica ATH-AD500 Right Headphone Cable Replacement
Wat je nodig hebt
  1. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Speaker Assembly: stap 1, afbeelding 1 van 1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Right Headphone Cable Replacement: stap 2, afbeelding 1 van 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Right Headphone Cable Replacement: stap 3, afbeelding 1 van 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: stap 4, afbeelding 1 van 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: stap 4, afbeelding 2 van 2
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference Hoe moet je (de-)solderen?.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Audio Technica ATH-AD500 Right Headphone Cable Replacement: stap 5, afbeelding 1 van 2 Audio Technica ATH-AD500 Right Headphone Cable Replacement: stap 5, afbeelding 2 van 2
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference Hoe moet je (de-)solderen?.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Melanie Reis
227 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-19, Forte Winter 2013 Lid van Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Leden
17 handleidingen geschreven
3 opmerkingen
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - Antwoord
Way late, but I would second information about finding a replacement cable.
Mateo Gomez - Antwoord
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 4,535
