Inleiding
This repair guide will help you with the following:
- Install the left headphone cable
- Fix sound coming from the left headphone
Wat je nodig hebt
Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference Hoe moet je (de-)solderen?.
Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference Hoe moet je (de-)solderen?.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
