Ga door naar hoofdinhoud
Atari Flashback 2 Reset and Select Button Replacement
Wat je nodig hebt
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: stap 1, afbeelding 1 van 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: stap 1, afbeelding 2 van 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: stap 1, afbeelding 3 van 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: stap 2, afbeelding 1 van 3 Atari Flashback 2 Reset and Select Button Replacement: stap 2, afbeelding 2 van 3 Atari Flashback 2 Reset and Select Button Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Conclusie
Gabriel Robinson
85 Reputatie
1 Handleiding geschreven
Washington State, Team S1-G2, Hope Fall 2018 Lid van Washington State, Team S1-G2, Hope Fall 2018
WSU-HOPE-F18S1G2
4 Leden
11 handleidingen geschreven
2 opmerkingen
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Antwoord
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 706
