Ga door naar hoofdinhoud
Atari Flashback 2 Joystick Button Replacement
Wat je nodig hebt
  1. Atari Flashback 2 Joystick Button Replacement, Joystick Button: stap 1, afbeelding 1 van 1
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Atari Flashback 2 Joystick Button Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
    • Remove the circuit board from the joystick housing.
  3. Atari Flashback 2 Joystick Button Replacement: stap 3, afbeelding 1 van 1
    • Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
  4. Atari Flashback 2 Joystick Button Replacement: stap 4, afbeelding 1 van 1
    • Remove the button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
Conclusie
Daniel Hoffman
209 Reputatie
1 Handleiding geschreven
Washington State, Team S1-G2, Hope Fall 2018 Lid van Washington State, Team S1-G2, Hope Fall 2018
WSU-HOPE-F18S1G2
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 371
