Ga door naar hoofdinhoud
Atari 5200 Number Pad Cleaning or Replacement
Wat je nodig hebt
  1. Atari 5200 Number Pad Cleaning or Replacement, Open the controller: stap 1, afbeelding 1 van 3 Atari 5200 Number Pad Cleaning or Replacement, Open the controller: stap 1, afbeelding 2 van 3 Atari 5200 Number Pad Cleaning or Replacement, Open the controller: stap 1, afbeelding 3 van 3
    • Turn the controller over.
    • Remove the three 6mm screws from the back.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Do not move the joystick when reassembling. This will break your alignment. The less the joystick is moved, the easier it will be to realign the joystick.
  2. Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): stap 2, afbeelding 1 van 3 Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): stap 2, afbeelding 2 van 3 Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): stap 2, afbeelding 3 van 3
    • Take out the rubber button module of the number pad.
    • Blow out dust on the number pad sensors with compressed air.
    • Wipe the sensors clean with a cloth dabbed with alcohol.
  3. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 1: stap 3, afbeelding 1 van 2 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 1: stap 3, afbeelding 2 van 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 2: stap 4, afbeelding 1 van 2 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 2: stap 4, afbeelding 2 van 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: stap 5, afbeelding 1 van 3 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: stap 5, afbeelding 2 van 3 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: stap 5, afbeelding 3 van 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws back into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alan Abelson
233 Reputatie
5 handleidingen geschreven
USF Tampa, Team 13-1, Staggers Fall 2014 Lid van USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Leden
17 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 824
