Ga door naar hoofdinhoud
Atari 5200 Motherboard Cleaning
Wat je nodig hebt
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: stap 1, afbeelding 1 van 1
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: stap 2, afbeelding 1 van 1
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: stap 3, afbeelding 1 van 1
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Zach Petryszyn
21 Reputatie
3 handleidingen geschreven
USF Tampa, Team 13-1, Staggers Fall 2014 Lid van USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Leden
17 handleidingen geschreven
Één opmerking
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 29
Altijd: 2,636
