Ga door naar hoofdinhoud
Atari 5200 Controller Side Buttons Replacement
Wat je nodig hebt
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: stap 1, afbeelding 1 van 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: stap 1, afbeelding 2 van 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: stap 1, afbeelding 3 van 3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: stap 2, afbeelding 1 van 2 Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: stap 2, afbeelding 2 van 2
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: stap 3, afbeelding 1 van 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: stap 3, afbeelding 2 van 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: stap 4, afbeelding 1 van 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: stap 4, afbeelding 2 van 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: stap 5, afbeelding 1 van 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: stap 5, afbeelding 2 van 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: stap 5, afbeelding 3 van 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alan Abelson
233 Reputatie
5 handleidingen geschreven
USF Tampa, Team 13-1, Staggers Fall 2014 Lid van USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Leden
17 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,242
