Ga door naar hoofdinhoud
Atari 2600 Jr. Rev. A Disassembly
Wat je nodig hebt
  1. Atari 2600 Jr. Rev. A Disassembly, Remove the base: stap 1, afbeelding 1 van 1
    • Remove 5 Phillips screws from base.
  2. Atari 2600 Jr. Rev. A Disassembly, Detach the Case: stap 2, afbeelding 1 van 3 Atari 2600 Jr. Rev. A Disassembly, Detach the Case: stap 2, afbeelding 2 van 3 Atari 2600 Jr. Rev. A Disassembly, Detach the Case: stap 2, afbeelding 3 van 3
    • Use a metal or heavy duty spudger to unhook the 3 plastic clips holding the front of the case together.
    • Be careful not to break the plastic clips
    • While unhooking the center hook use another spudger to run along the top and bottom casing. This helps to get the clip lose.
    • Be careful not to pull the case apart quickly, there is a ribbon that is attached to the top and bottom.
  3. Atari 2600 Jr. Rev. A Disassembly, Detach the Ribbon: stap 3, afbeelding 1 van 1
    • Detach the ribbon from the circuit board by gently pulling ribbon out from clip.
  4. Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: stap 4, afbeelding 1 van 2 Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: stap 4, afbeelding 2 van 2
    • There are 2 clips holding the circuit board in place.
    • Using a metal or heavy duty spudger release the clip on the left side.
    • Remove the circuit board.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Aislinn
267 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 69
Altijd: 3,872
