Inleiding
If your phone fails to charge, it could be due to a malfunctioning charging port. A charging port can be easily damaged by water, corrosion, and debris. This guide will help you replace your damaged charging port
Wat je nodig hebt
Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
Once the battery has been removed, gently wedge the metal spudger beneath the green panel.
Lift the panel along with the charging port out the device and replace with the new charging port.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
repair microfone asus zenfone 4 selfie pro please
I have managed to replace the charging port but now it shows Charging Port Temperatures Abnormalities Reminder which is loud and annoying to see every time. I also see that one of my sensors in the cpu-z program (thermal sensor pa_therm0) hitting a constant 75-84 degree centigrade and another sensor (chg_temp) hitting 65 constantly. Any help in regards to this manner?
