Ga door naar hoofdinhoud
Asus Zenfone 4 Max Camera Replacement
Wat je nodig hebt
  1. Asus Zenfone 4 Max Camera Replacement, Camera: stap 1, afbeelding 1 van 1
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: stap 2, afbeelding 1 van 1
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: stap 3, afbeelding 1 van 2 Asus Zenfone 4 Max Camera Replacement: stap 3, afbeelding 2 van 2
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: stap 4, afbeelding 1 van 3 Asus Zenfone 4 Max Camera Replacement: stap 4, afbeelding 2 van 3 Asus Zenfone 4 Max Camera Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Conclusie
Maegan West
839 Reputatie
4 handleidingen geschreven
2 opmerkingen
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - Antwoord
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 1,954
