Ga door naar hoofdinhoud
Asus Zenfone 4 Max Battery Replacement
Wat je nodig hebt
  1. Asus Zenfone 4 Max Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Asus Zenfone 4 Max Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
  2. Asus Zenfone 4 Max Battery Replacement: stap 2, afbeelding 1 van 1
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  3. Asus Zenfone 4 Max Battery Replacement: stap 3, afbeelding 1 van 3 Asus Zenfone 4 Max Battery Replacement: stap 3, afbeelding 2 van 3 Asus Zenfone 4 Max Battery Replacement: stap 3, afbeelding 3 van 3
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  4. Asus Zenfone 4 Max Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the bottom panel.
  5. Asus Zenfone 4 Max Battery Replacement: stap 5, afbeelding 1 van 2 Asus Zenfone 4 Max Battery Replacement: stap 5, afbeelding 2 van 2
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  6. Asus Zenfone 4 Max Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery and replace it with the new battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Maegan West
839 Reputatie
4 handleidingen geschreven
4 opmerkingen
My FPC connector is broken as well as female battery connector, are these worth the time and money to replace or are new motherboards available?
Off topic: But anyone have success removing glass without damaging digitizer without any specialized tools on a xooid I have two 4max pro i have a new glass only:/uv glue / two back case, home buttons,2 replacement earpiece speakers, two sim trays, one rose gold and white one black on black, both useless now. Any advice of sourcing parts, or try to seperate glass, desolder and replace battery connectors or just scrap it all?
joemarvcontractor - Antwoord
Can you explain more what kind of a screwdriver do you need. On the tools it says that you need a philips #0 bit but in the guide itself it says that you need a t3 and a at3 bit. I can’t find any info on an at3 bit. Please explain. Thank you.
Some One - Antwoord
A few more screws then mentioned - one at bottom and one at top to release battery connector. Go slow!
I had to use a Torque 2 for the first two at the charging jack NOT Torque 3. The rest are small Phillips.
You certainly need the prior bars to get the back off the first time as it ‘stuck’ - so is the battery.
IMPORTANT - take the slide with the memory and phone chip out before starting. Just go slow and careful.
Gord MacSwain - Antwoord
Trop vieux pour que je change la batterie surtout si c'est pour tomber sur un rebus hors d'âge, hop recyclage de ce smartphone qui m'aura rendu de bons services mais qui ramait depuis quelques mois déjà. J'attendais juste un bon prétexte pour changer. Enfin pour la panne c'est la nappe d'alimentation de la batterie qui est coupé au milieu je sais pas pourquoi... (peut être les chutes multiples). Mais à 150€ pour 4 ans et 7 mois d'utilisation je trouve que c'est largement amorti et qu'il est grand temps de changer de modèle.
Manuel Cochet - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 62
Altijd: 11,105
