Inleiding
Use this guide to replace noisy or malfunctioning GPU fan in the Asus Zenbook UX32VD.
Wat je nodig hebt
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
Remove the metallic ribbon cable from the connector .
Remove the 3 (4mm) fan screws with a Phillips #0 Screwdriver
Bijna klaar!
Conclusie
