Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Carefully slide your iFixit Opening Tool between the back panel.
Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Remove the screw connecting the speaker component to the motherboard using the screwdriver.
Using the plastic opening tool, pry open the speaker component from the computer.
