Ga door naar hoofdinhoud
Inleiding
If your audio is distorted, replace the speaker component to get fresh, clear sound.
Onderdelen
Geen onderdelen opgegeven.
  1. Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Carefully slide your iFixit Opening Tool between the back panel.
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Use the plastic opening tool to pry open the back cover of the laptop.
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  4. Remove the screw connecting the speaker component to the motherboard using the screwdriver. Remove the screw connecting the speaker component to the motherboard using the screwdriver.
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  5. Disconnect the sound cable from the motherboard. Disconnect the sound cable from the motherboard.
    • Disconnect the sound cable from the motherboard.
  6. Using the plastic opening tool, pry open the speaker component from the computer. Using the plastic opening tool, pry open the speaker component from the computer.
    • Using the plastic opening tool, pry open the speaker component from the computer.
Conclusie
Zachary Somerscales
146 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 1-2, Rose Winter 2017 Lid van UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Leden
9 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 2,096
