Ga door naar hoofdinhoud
Asus Zenbook UX31E SSD Replacement
Wat je nodig hebt
  1. Asus Zenbook UX31E SSD Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E SSD Replacement: stap 2, afbeelding 1 van 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E SSD Replacement, SSD: stap 3, afbeelding 1 van 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  4. Asus Zenbook UX31E SSD Replacement: stap 4, afbeelding 1 van 2 Asus Zenbook UX31E SSD Replacement: stap 4, afbeelding 2 van 2
    • Using your hand, pull the SSD out from its slot.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Charles Jackson
668 Reputatie
3 handleidingen geschreven
UW Tacoma, Team 1-2, Rose Winter 2017 Lid van UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Leden
9 handleidingen geschreven
Één opmerking
Vorrei fare una precisazione, l’SSD che monta questo laptop ha un attacco XM11, oramai non si usa più, pertanto è vero che possiamo sostituirlo ma dobbiamo aver cura di prendere un SSD M2 (2280) e un adattatore, io ho trovato su Amazon questo https://www.amazon.it/gp/product/B00XJRQ...
e ho preso come SSD un Crucial MX500 CT1000MX500SSD4 SSD Interno, 1 TB, 3D NAND, SATA, M.2 (2280)
Davide Bortot - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 12,235
