Ga door naar hoofdinhoud
Asus Zenbook UX31E Motherboard Replacement
Wat je nodig hebt
  1. Asus Zenbook UX31E Motherboard  Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Motherboard  Replacement: stap 2, afbeelding 1 van 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Motherboard  Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  4. Asus Zenbook UX31E Motherboard  Replacement: stap 4, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 4, afbeelding 2 van 2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  5. Asus Zenbook UX31E Motherboard  Replacement: stap 5, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the sound cable from the motherboard.
  6. Asus Zenbook UX31E Motherboard  Replacement: stap 6, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 6, afbeelding 2 van 2
    • Using the plastic opening tool, pry open the speaker component from the computer.
  7. Asus Zenbook UX31E Motherboard  Replacement, Battery: stap 7, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement, Battery: stap 7, afbeelding 2 van 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  8. Asus Zenbook UX31E Motherboard  Replacement: stap 8, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 8, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  9. Asus Zenbook UX31E Motherboard  Replacement: stap 9, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 9, afbeelding 2 van 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
  10. Asus Zenbook UX31E Motherboard  Replacement, SSD: stap 10, afbeelding 1 van 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  11. Asus Zenbook UX31E Motherboard  Replacement: stap 11, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 11, afbeelding 2 van 2
    • Using your hand, pull the SSD out from its slot.
  12. Asus Zenbook UX31E Motherboard  Replacement, Fan: stap 12, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement, Fan: stap 12, afbeelding 2 van 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  13. Asus Zenbook UX31E Motherboard  Replacement: stap 13, afbeelding 1 van 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  14. Asus Zenbook UX31E Motherboard  Replacement: stap 14, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 14, afbeelding 2 van 2
    • Unscrew the two screws that are across each other.
  15. Asus Zenbook UX31E Motherboard  Replacement: stap 15, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 15, afbeelding 2 van 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
  16. Asus Zenbook UX31E Motherboard  Replacement, Motherboard: stap 16, afbeelding 1 van 3 Asus Zenbook UX31E Motherboard  Replacement, Motherboard: stap 16, afbeelding 2 van 3 Asus Zenbook UX31E Motherboard  Replacement, Motherboard: stap 16, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
    • Remove the press fit connector attaching the motherboard to the screen.
    • Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
  17. Asus Zenbook UX31E Motherboard  Replacement: stap 17, afbeelding 1 van 2 Asus Zenbook UX31E Motherboard  Replacement: stap 17, afbeelding 2 van 2
    • Lift gently and flip the motherboard over in the direction of the track pad.
    • Peel off the the yellow tape.
    • Detach the ZIF connector on the underside of the motherboard connecting it to the keyboard.
    • Remove the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Boa Tarde
Tenho um equipamento igual não está apresentando imagen no LCD fica o power e caps look ligado e apenas arranca o cooller nada mais
renatoxornelas - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 1,757
