Inleiding
Using this guide you will discover how to access and remove the keyboard from the bottom of your Asus Zenbook UX31E. This is used to fix a broken, or damaged keyboard or if the keyboard stops working. You will begin by removing the back cover. After that, you will gently remove the battery, speaker, motherboard, and fan to reveal the keyboard for replacement. To reinstall the new keyboard you will follow the steps in reverse order.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
Remove the press fit connector attaching the motherboard to the screen.
Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
Één andere persoon heeft deze handleiding voltooid.
