Ga door naar hoofdinhoud
Asus Zenbook UX31E Battery Replacement
Wat je nodig hebt
  1. Asus Zenbook UX31E Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
    Can you tell me what size these screws are? I need to replace two.
    Elliot Lozano - Antwoord
    I don’t know, but you can search with product code: VISTORXUX31E
    See also: https://en.accessoires-asus.com/torx-scr...|l
    Davide Bortot -
  2. Asus Zenbook UX31E Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Asus Zenbook UX31E Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E Battery Replacement: stap 4, afbeelding 1 van 2 Asus Zenbook UX31E Battery Replacement: stap 4, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E Battery Replacement: stap 5, afbeelding 1 van 2 Asus Zenbook UX31E Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
Conclusie
5 andere personen hebben deze handleiding voltooid.
Hersi Dahir
203 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 1-2, Rose Winter 2017 Lid van UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Leden
9 handleidingen geschreven
2 opmerkingen
Thanks for the easy to understand guide. Cheers!
Rahul Kashelani - Antwoord
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
fiddyfadhlina - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 7,797
