Ga door naar hoofdinhoud
Asus Zenbook UX303L Speaker Replacement
Wat je nodig hebt
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: stap 7, afbeelding 1 van 1
    • Carefully peel away the defective speakers from the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Snow
202 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G6, Harley Spring 2019 Lid van IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Leden
7 handleidingen geschreven
Één opmerking
Is the Asus UX303L same as U303L?
Michael Wolf - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 29
Altijd: 1,795
