Ga door naar hoofdinhoud
Asus Zenbook UX21e Solid-State Drive Replacement
Wat je nodig hebt
  1. Asus Zenbook UX21e Solid-State Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Asus Zenbook UX21e Solid-State Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Asus Zenbook UX21e Solid-State Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
    • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
  2. Asus Zenbook UX21e Solid-State Drive Replacement: stap 2, afbeelding 1 van 3 Asus Zenbook UX21e Solid-State Drive Replacement: stap 2, afbeelding 2 van 3 Asus Zenbook UX21e Solid-State Drive Replacement: stap 2, afbeelding 3 van 3
    • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
  3. Asus Zenbook UX21e Solid-State Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • One at each corner and one in the center.
  4. Asus Zenbook UX21e Solid-State Drive Replacement: stap 4, afbeelding 1 van 2 Asus Zenbook UX21e Solid-State Drive Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery directly up and remove it from the device.
  5. Asus Zenbook UX21e Solid-State Drive Replacement, Solid-State Drive: stap 5, afbeelding 1 van 3 Asus Zenbook UX21e Solid-State Drive Replacement, Solid-State Drive: stap 5, afbeelding 2 van 3 Asus Zenbook UX21e Solid-State Drive Replacement, Solid-State Drive: stap 5, afbeelding 3 van 3
    • Unscrew the single 3mm screw with a Phillips #1 screwdriver at the rightmost edge of the Hard Drive.
    • Remove the Hard Drive by sliding it parallel to the motherboard.
Conclusie
Zachary Eslick
756 Reputatie
5 handleidingen geschreven
Cal Poly, Team S22-G1, Maness Spring 2018 Lid van Cal Poly, Team S22-G1, Maness Spring 2018
CPSU-MANESS-S18S22G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 4,687
