Ga door naar hoofdinhoud
Asus ZenFone 5 Battery Replacement
Wat je nodig hebt
  1. Asus ZenFone 5 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Asus ZenFone 5 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Asus ZenFone 5 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
    • Pull out the SIM card tray.
  2. Asus ZenFone 5 Battery Replacement: stap 2, afbeelding 1 van 3 Asus ZenFone 5 Battery Replacement: stap 2, afbeelding 2 van 3 Asus ZenFone 5 Battery Replacement: stap 2, afbeelding 3 van 3
    • It may help to apply heat to the back cover using either a heat gun or an iOpener before starting to remove the cover.
    • Use a plastic opening pick to pry into the crease between the back cover and the midframe of the phone.
    • Move all the way around the phone until the back cover is separated from the rest of the phone.
    • The images show a metal spudger being used to pry open the back cover. However, this process is not recommended, as it poses a puncture risk to the battery.
  3. Asus ZenFone 5 Battery Replacement: stap 3, afbeelding 1 van 3 Asus ZenFone 5 Battery Replacement: stap 3, afbeelding 2 van 3 Asus ZenFone 5 Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove the six screws across the top mid frame and gently lift the top assembly piece. It should detach easily and can be set aside.
  4. Asus ZenFone 5 Battery Replacement: stap 4, afbeelding 1 van 3 Asus ZenFone 5 Battery Replacement: stap 4, afbeelding 2 van 3 Asus ZenFone 5 Battery Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to release the red square that is holding the bottom assembly piece from the frame.
    • Using a Phillips #00 screwdriver, remove the five screws from the bottom midframe.
    • Gently remove the bottom midframe.
  5. Asus ZenFone 5 Battery Replacement: stap 5, afbeelding 1 van 2 Asus ZenFone 5 Battery Replacement: stap 5, afbeelding 2 van 2
    • Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
    • Gently pry the battery out of the case, taking care not to bend or puncture the battery.
    • It may help to apply a bit of heat through the screen to loosen the battery adhesive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Wait, Asus Zenfone 5 (ZE620KL, ZF620KL) has only 3300 mAh battery capacity. Why in the image above the battery label say it's 4000 mAh?
Jufans Anurwan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 109
Altijd: 3,502
