Ga door naar hoofdinhoud
Asus ZenBook Flip UX360C Motherboard Replacement
Wat je nodig hebt
  1. Asus ZenBook Flip UX360C Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove all ten T5 screws on the back cover near the edges.
    • Remove two Phillips #1 screws located under the rubber feet near the screen.
  2. Asus ZenBook Flip UX360C Motherboard Replacement: stap 2, afbeelding 1 van 3 Asus ZenBook Flip UX360C Motherboard Replacement: stap 2, afbeelding 2 van 3 Asus ZenBook Flip UX360C Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use a metal spudger to gently separate the keyboard from the computer case.
    • Do not completely remove the keyboard as there are two ribbon cables that connect the keyboard to the motherboard.
    • Lift the keyboard slightly, and use a plastic spudger to release the two ZIF connections to free each ribbon cable.
    • Remove the keyboard.
  3. Asus ZenBook Flip UX360C Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to remove all 5 mm screws.
  4. Asus ZenBook Flip UX360C Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool or nylon spudger to lift the monitor connections off of the main board.
  5. Asus ZenBook Flip UX360C Motherboard Replacement: stap 5, afbeelding 1 van 2 Asus ZenBook Flip UX360C Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Clip off the battery from the main board.
    • Use of a metal spudger can cause damage to the device or harm to the user, especially near the battery! Use an ESD safe tool for this step instead.
  6. Asus ZenBook Flip UX360C Motherboard Replacement: stap 6, afbeelding 1 van 2 Asus ZenBook Flip UX360C Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the black foam above the screw on the I/O board.
    • Remove the 5 mm #1 Phillips head screw.
  7. Asus ZenBook Flip UX360C Motherboard Replacement: stap 7, afbeelding 1 van 2 Asus ZenBook Flip UX360C Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Pull the I/O board away from the chip to detach it.
    • Remove the I/O board and main board.
Conclusie
Jonathan Heintz
145 Reputatie
1 Handleiding geschreven
Één opmerking
where can i buy the motherboard?
Thevan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 3,047
