Ga door naar hoofdinhoud
Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement
Wat je nodig hebt
  1. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, Screen: stap 1, afbeelding 1 van 2 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, Screen: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
    • The strip is held in place with adhesive. You may hear a crackling sound as the strip is peeled off.
    • Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
  2. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 2, afbeelding 1 van 2 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the seven (7) 4.8 mm screws from the base of the screen.
  3. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 3, afbeelding 1 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 3, afbeelding 2 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 3, afbeelding 3 van 3
    • Place the computer on its back, facing up.
    • Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
    • Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
    • The screen is held in place by plastic tabs. These will create a popping sound when loosened.
    • The screen assembly will flex as it is pried off. Do not bend the screen too far or the glass screen could shatter.
  4. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 4, afbeelding 1 van 1
    • Lift the screen from the bottom edge by about 6 inches. Prop it open with one hand.
    • Look inside the computer and locate five (5) cables that connect the embedded components of the screen (camera, microphone, etc.) to the rest of the computer.
  5. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 5, afbeelding 1 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 5, afbeelding 2 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 5, afbeelding 3 van 3
    • Remove the two (2) cables that are connected to the computer by white, rectangular terminal blocks by pulling straight out on the plug.
    • The cables and wires in these steps are delicate; do not tug on the individual wires that make up each cable.
  6. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 6, afbeelding 1 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 6, afbeelding 2 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 6, afbeelding 3 van 3
    • Use a finger to lift the plastic locking flaps that hold the remaining three (3) ribbon cables in place.
    • Remove the cables from their terminals by slipping them away from their connectors.
    • The black line on the ribbon cables mark the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
  7. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, WiFi (WLAN) Card: stap 7, afbeelding 1 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, WiFi (WLAN) Card: stap 7, afbeelding 2 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, WiFi (WLAN) Card: stap 7, afbeelding 3 van 3
    • Locate the WLAN card in the upper left hand corner of the computer.
    • Use a Phillips #1 screwdriver to remove the 3.2 mm screw on the top of the WLAN card.
  8. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 8, afbeelding 1 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 8, afbeelding 2 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 8, afbeelding 3 van 3
    • Pull out the WLAN card from its socket.
    • Remove the two antennae wires from the WLAN card by pulling up on the coaxial connectors.
  9. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, Fan: stap 9, afbeelding 1 van 2 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, Fan: stap 9, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the three (3) 4.8 mm screws from the fan unit.
    • Remove the cable connecting the fan to the motherboard by pulling the cable out of its socket.
  10. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 10, afbeelding 1 van 1
    • Remove the fan by peeling off the black electrical tape holding it against the heat sink vents.
  11. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, Motherboard: stap 11, afbeelding 1 van 1
    • Remove the six (6) ribbon cables by lifting up on the plastic locking tabs and then slipping the cables out of their sockets.
    • Remove the other two (2) cables by pulling straight out on the white connectors.
    • One ribbon cable is hidden beneath black tape.
    • The motherboard is ESD sensitive. Limit your contact with the green circuit board surface and electrical components. When handling the board, hold it by the edges.
    • The black lines on the ribbon cables mark the connecting region. When reinstalling, insert the cables up to this line so the locking flap covers it.
  12. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 12, afbeelding 1 van 2 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 12, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove nine (9) 3.2 mm screws from the motherboard.
    • Two of the screws near the middle of the board are hidden beneath padding.
    • Use a Phillips #1 screwdriver to remove the one (1) 4.8 mm screw directly below the copper heat sink channel.
  13. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 13, afbeelding 1 van 2 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 13, afbeelding 2 van 2
    • Lift the motherboard just enough to dismount it from the plastic pegs that hold it in place.
    • Rotate the motherboard towards yourself while supporting the heat sink by pivoting on its bottom edge.
  14. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 14, afbeelding 1 van 2 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement: stap 14, afbeelding 2 van 2
    • Remove the SATA cable on the opposite side of the motherboard by pulling directly up from the board.
  15. Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, USB and HDMI Ports: stap 15, afbeelding 1 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, USB and HDMI Ports: stap 15, afbeelding 2 van 3 Asus Zen AiO Pro Z240IC USB and HDMI Ports Replacement, USB and HDMI Ports: stap 15, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the five (5) 3.2 mm screws.
    • Two of the screws are hidden underneath the ribbon cables and black tape.
    • Remove the board by lifting it upwards.
Conclusie
Jessica Lerena
630 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G1, Livingston Fall 2017 Lid van Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 Leden
25 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 1,028
