Ga door naar hoofdinhoud
Asus X751L Battery Replacement
Wat je nodig hebt
  1. Asus X751L Battery Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: stap 3, afbeelding 1 van 3 Asus X751L Battery Replacement: stap 3, afbeelding 2 van 3 Asus X751L Battery Replacement: stap 3, afbeelding 3 van 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: stap 5, afbeelding 1 van 2 Asus X751L Battery Replacement: stap 5, afbeelding 2 van 2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: stap 6, afbeelding 1 van 3 Asus X751L Battery Replacement: stap 6, afbeelding 2 van 3 Asus X751L Battery Replacement: stap 6, afbeelding 3 van 3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
John Enderton
576 Reputatie
2 handleidingen geschreven
USF Tampa, Team 17-2, Blackwell Spring 2017 Lid van USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Leden
5 handleidingen geschreven
6 opmerkingen
Very nice, thank you !
anh
barzamjavel - Antwoord
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Antwoord
Your instructions were easy to follow. Thank you!!!
theresa collet - Antwoord
very helpful
khan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 44
Altijd: 13,266
