Inleiding
We will show you how to open the laptop and change / upgrade the HDD (hard disk drive).
Please SUBSCRIBE to my channel ツ
Video overzicht
  1. Switch off the Laptop and remove the Battery. Unscrew the two Philips screws and remove the HDD / RAM Cover. Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Remove three screws securing the hard drive caddy (hard drive assembly). Slide the hard drive assembly to the left to disconnect it from the motherboard. Slide the hard drive assembly to the left to disconnect it from the motherboard.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  4. Remove the two Philips screws and separate the HDD from the caddy case.
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
Conclusie
3 andere personen hebben deze handleiding voltooid.
ZFix
162.350 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
783 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 4
Afgelopen 7 Dagen: 16
Afgelopen 30 Dagen: 95
Altijd: 6,665
