Inleiding
You may need to replace the CD Drive if it is not working, or if you want a more advanced CD Drive. This is a fairly easy replacement, and there is not too much else you need to take off of the device in order to get the CD Drive out. The CD Drive is essentially its own entity, so there will not be any other parts that need to come out with it. There is no easy way to repair a CD Drive itself, so if you have determined that your drive is not working, the best option is going to be to replace the whole thing.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the following Phillips #0 screws from the lower case:
Six 9 mm screws
Four 11 mm screws
Using a #0 Phillips screw driver, remove the (5mm) black screw to the left of the CD Drive and to the right of the cooling fan.
9 andere personen hebben deze handleiding voltooid.
