Ga door naar hoofdinhoud
Asus X551CA Front Display Bezel Replacement
Wat je nodig hebt
  1. Asus X551CA Front Display Bezel Replacement, Keyboard Plate Cover: stap 1, afbeelding 1 van 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Front Display Bezel Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Front Display Bezel Replacement: stap 3, afbeelding 1 van 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Front Display Bezel Replacement: stap 4, afbeelding 1 van 3 Asus X551CA Front Display Bezel Replacement: stap 4, afbeelding 2 van 3 Asus X551CA Front Display Bezel Replacement: stap 4, afbeelding 3 van 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Front Display Bezel Replacement: stap 5, afbeelding 1 van 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Front Display Bezel Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  7. Asus X551CA Front Display Bezel Replacement: stap 7, afbeelding 1 van 1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  8. Asus X551CA Front Display Bezel Replacement: stap 8, afbeelding 1 van 1
    • Once it is free, remove the hard drive from its internal cavity.
  9. Asus X551CA Front Display Bezel Replacement, Spacer: stap 9, afbeelding 1 van 1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
  10. Asus X551CA Front Display Bezel Replacement: stap 10, afbeelding 1 van 1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
  11. Asus X551CA Front Display Bezel Replacement, WiFi Card: stap 11, afbeelding 1 van 1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
  12. Asus X551CA Front Display Bezel Replacement: stap 12, afbeelding 1 van 1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
  13. Asus X551CA Front Display Bezel Replacement: stap 13, afbeelding 1 van 1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
  14. Asus X551CA Front Display Bezel Replacement, Battery: stap 14, afbeelding 1 van 1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
  15. Asus X551CA Front Display Bezel Replacement, Motherboard: stap 15, afbeelding 1 van 1
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
  16. Asus X551CA Front Display Bezel Replacement: stap 16, afbeelding 1 van 2 Asus X551CA Front Display Bezel Replacement: stap 16, afbeelding 2 van 2
    • Now, locate the two wires connected to the motherboard.
  17. Asus X551CA Front Display Bezel Replacement: stap 17, afbeelding 1 van 2 Asus X551CA Front Display Bezel Replacement: stap 17, afbeelding 2 van 2
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
  18. Asus X551CA Front Display Bezel Replacement: stap 18, afbeelding 1 van 2 Asus X551CA Front Display Bezel Replacement: stap 18, afbeelding 2 van 2
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
  19. Asus X551CA Front Display Bezel Replacement: stap 19, afbeelding 1 van 1
    • Remove the motherboard from the case by gently lifting it upward.
  20. Asus X551CA Front Display Bezel Replacement, Front Display Bezel: stap 20, afbeelding 1 van 1
    • Locate both of the hinges that connect the monitor to the bottom plate cover.
  21. Asus X551CA Front Display Bezel Replacement: stap 21, afbeelding 1 van 2 Asus X551CA Front Display Bezel Replacement: stap 21, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
  22. Asus X551CA Front Display Bezel Replacement: stap 22, afbeelding 1 van 1
    • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
  23. Asus X551CA Front Display Bezel Replacement: stap 23, afbeelding 1 van 1
    • Locate the two stickers that cover up the screws that hold the front bezel in place
  24. Asus X551CA Front Display Bezel Replacement: stap 24, afbeelding 1 van 2 Asus X551CA Front Display Bezel Replacement: stap 24, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to remove these stickers.
    • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
  25. Asus X551CA Front Display Bezel Replacement: stap 25, afbeelding 1 van 1
    • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
  26. Asus X551CA Front Display Bezel Replacement: stap 26, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
  27. Asus X551CA Front Display Bezel Replacement: stap 27, afbeelding 1 van 2 Asus X551CA Front Display Bezel Replacement: stap 27, afbeelding 2 van 2
    • Once the screws are taken out, the front bezel is ready to be removed.
    • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
    • Gently use hands if necessary to separate the front bezel from the back.
  28. Asus X551CA Front Display Bezel Replacement: stap 28, afbeelding 1 van 1
    • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Josh
2.958 Reputatie
12 handleidingen geschreven
Cal Poly, Team 7-22, Regan Spring 2014 Lid van Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 4,478
