Ga door naar hoofdinhoud
Asus X550ZA-SA100603E RAM Replacement
Wat je nodig hebt
  1. Asus X550ZA-SA100603E RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them.
    • Seven 14 mm screws
    • Three 4 mm screws
    • Make sure to keep the screws for reassembly.
  2. Asus X550ZA-SA100603E RAM Replacement: stap 2, afbeelding 1 van 1
    • Carefully turn the computer onto its bottom, and gently pull the bottom apart from the top.
  3. Asus X550ZA-SA100603E RAM Replacement: stap 3, afbeelding 1 van 1
    • Take a flathead driver, and gently pry open a gap between the keyboard and the lower piece. This should uncover the laptop's internals.
    • The flathead driver has the potential to damage the device. Be careful when handling it.
    • Do not be alarmed if you hear a click as you pry open. These sounds are the clips detaching from the casing.
  4. Asus X550ZA-SA100603E RAM Replacement: stap 4, afbeelding 1 van 2 Asus X550ZA-SA100603E RAM Replacement: stap 4, afbeelding 2 van 2
    • The motherboard is the big board on the left-hand side of the internals. Remove all 15 bordering screws that hold the motherboard in place.
  5. Asus X550ZA-SA100603E RAM Replacement: stap 5, afbeelding 1 van 2 Asus X550ZA-SA100603E RAM Replacement: stap 5, afbeelding 2 van 2
    • Carefully flip the motherboard over to expose the bottom of the board. You should find the RAM slots located on the right-hand side of the bottom of the motherboard.
  6. Asus X550ZA-SA100603E RAM Replacement: stap 6, afbeelding 1 van 1
    • Take two fingers and pull the securing slots outward. The RAM stick should easily pop out. Take the old stick out, and carefully put the new one in the slot.
    • You will hear a clicking noise once it is pushed in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Paul Flynn
16 Reputatie
2 handleidingen geschreven
IUPUI, Team S5-G5, Wilson Spring 2019 Lid van IUPUI, Team S5-G5, Wilson Spring 2019
IUPUI-WILSON-S19S5G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 412
