Ga door naar hoofdinhoud
Asus X550ZA-SA100603E Keyboard Replacement
Wat je nodig hebt
  1. Asus X550ZA-SA100603E Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Keyboard Replacement: stap 2, afbeelding 1 van 3 Asus X550ZA-SA100603E Keyboard Replacement: stap 2, afbeelding 2 van 3 Asus X550ZA-SA100603E Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Keyboard Replacement: stap 3, afbeelding 1 van 3 Asus X550ZA-SA100603E Keyboard Replacement: stap 3, afbeelding 2 van 3 Asus X550ZA-SA100603E Keyboard Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Keyboard Replacement: stap 4, afbeelding 1 van 3 Asus X550ZA-SA100603E Keyboard Replacement: stap 4, afbeelding 2 van 3 Asus X550ZA-SA100603E Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the keyboard.
Conclusie
Één opmerking
Hello
May I know how to plug in the keyboard ribbon cable (the big one)?
I've tried to push the white clamp before plugging the cable, but it is stuck (it cannot be completely plugged in), and it can be easily removed as if the cable is not locked.
Thanks in advance.
Kurisada Santo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 27
Altijd: 1,046
