Ga door naar hoofdinhoud
Asus X550ZA-SA100603E Hard Drive Replacement
Wat je nodig hebt
  1. Asus X550ZA-SA100603E Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Remove all of the 10 bottom case screws.
    • Seven of them are 14 mm screws.
    • Three of them are 4 mm screws.
  2. Asus X550ZA-SA100603E Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • After the screws are removed, gently turn the computer to its upright position and open up the computer flap.
    • It is important to do this gently, as these pieces are loose.
  3. Asus X550ZA-SA100603E Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Pry open a gap between the keyboard and the lower piece using a spudger.
    • This will uncover all of the internals in the laptop itself.
  4. Asus X550ZA-SA100603E Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Slide the hard drive out of its position to allow room for the new one.
    • Make certain the area is clean and no debris got into the slot.
Conclusie
Paul Flynn
16 Reputatie
2 handleidingen geschreven
IUPUI, Team S5-G5, Wilson Spring 2019 Lid van IUPUI, Team S5-G5, Wilson Spring 2019
IUPUI-WILSON-S19S5G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 464
