Ga door naar hoofdinhoud
Asus X54C Keyboard Replacement
Wat je nodig hebt
Video overzicht
  1. Asus X54C Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Asus X54C Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Disconnect the charger and switch off the laptop.
    • Two keys keep locked battery.
  2. Asus X54C Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 3 Asus X54C Keyboard Replacement, Keyboard: stap 2, afbeelding 2 van 3 Asus X54C Keyboard Replacement, Keyboard: stap 2, afbeelding 3 van 3
    • The Keyboard is held by 5x locking clips.
    • Use a tool with with a thin tip and lift slightly the KB from the left side.
    • Unlock clips one by one.
    • Disconnect the KB ribbon cable.
Conclusie
9 andere personen hebben deze handleiding voltooid.
ZFix
192.005 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.518 handleidingen geschreven
2 opmerkingen
Thanks for the detailed vid! What are the materials used at 07:00-08:00 to clean and replace the paste? Specifically what's in the spray bottle and the syringe
Buster Cluster - Antwoord
Hello,
To clean the thermal paste, the author used a soft toothbrush (probably with isopropyllic alcohol).
The syringe contains a non-conductive thermal paste.
You can replace the toothbrush by cell polyurethane foam swabs and isopropilic alcohol to remove the old thermal paste if you want.
This is a laptop with a CPU that doesn't heat too much, so you can replace the original thermal paste by any non conductive thermal paste made to be used in computers it will be fine.
Brendan -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 6,578
