Inleiding
The screen or display of your laptop may break because of physical damage. If so, you can replace it using this guide.
Wat je nodig hebt
Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
Flip the laptop around and lay the screen flat on your work space with the laptop hinge away from you and the keyboard assembly standing vertical.
Bijna klaar!
Conclusie
