Ga door naar hoofdinhoud
Asus X502C-RB01 Hard Drive Replacement
Wat je nodig hebt
  1. Asus X502C-RB01 Hard Drive Replacement, Keyboard Panel: stap 1, afbeelding 1 van 1
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Asus X502C-RB01 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 Hard Drive Replacement: stap 4, afbeelding 1 van 2 Asus X502C-RB01 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
  6. Asus X502C-RB01 Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
  7. Asus X502C-RB01 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
  8. Asus X502C-RB01 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jaspal Chauhan
491 Reputatie
4 handleidingen geschreven
UC Davis, Team 1-5, Rodger Winter 2017 Lid van UC Davis, Team 1-5, Rodger Winter 2017
UCD-RODGER-W17S1G5
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 25
Altijd: 2,617
