Ga door naar hoofdinhoud
Asus X501A-RH31 LCD Replacement
Romana Hruby
Romana Hruby en 3 andere bijdragers
Voor het laatst geüpdatet op December 21, 2017
45 minuten
Moeilijk
The purpose of this guide is to show how to effectively remove the LCD. Please note that the screen is fragile and too much pressure applied will damage the screen.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Asus X501A-RH31 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 LCD Replacement: stap 2, afbeelding 1 van 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 LCD Replacement: stap 3, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 3, afbeelding 2 van 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 LCD Replacement, Keyboard: stap 4, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 LCD Replacement: stap 5, afbeelding 1 van 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 LCD Replacement: stap 6, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 6, afbeelding 2 van 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 LCD Replacement: stap 7, afbeelding 1 van 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 LCD Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 LCD Replacement, Fan: stap 9, afbeelding 1 van 1
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 LCD Replacement: stap 10, afbeelding 1 van 1
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 LCD Replacement: stap 11, afbeelding 1 van 3 Asus X501A-RH31 LCD Replacement: stap 11, afbeelding 2 van 3 Asus X501A-RH31 LCD Replacement: stap 11, afbeelding 3 van 3
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
  12. Asus X501A-RH31 LCD Replacement, Motherboard: stap 12, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Unscrew the six screws that hold the motherboard to the bottom of the laptop using a Phillips #00 screwdriver.
    • The six screws are 4.2 mm long, 5 mm in diameter.
  13. Asus X501A-RH31 LCD Replacement: stap 13, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 13, afbeelding 2 van 2
    • Unlatch the data cable by using tweezers to lift the white tab and release the cable.
  14. Asus X501A-RH31 LCD Replacement: stap 14, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 14, afbeelding 2 van 2
    • Remove the cable on the left side of the motherboard.
    • Use tweezers to pull the white tab up in order to release this cable.
  15. Asus X501A-RH31 LCD Replacement: stap 15, afbeelding 1 van 1
    • On the left side is a small piece of the motherboard. Unscrew the two screws holding this piece down with the Phillips #00 screwdriver.
    • The two screws are 6 mm long, 4.2 mm in diameter.
  16. Asus X501A-RH31 LCD Replacement: stap 16, afbeelding 1 van 3 Asus X501A-RH31 LCD Replacement: stap 16, afbeelding 2 van 3 Asus X501A-RH31 LCD Replacement: stap 16, afbeelding 3 van 3
    • Release the connector cable on the back right side of the motherboard.
    • Peel off the tape with tweezers so that the cable can be released.
    • Using the black plastic spudger, push the back half of the cable towards the screen.
  17. Asus X501A-RH31 LCD Replacement: stap 17, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 17, afbeelding 2 van 2
    • Grip the motherboard firmly and pull the board leftward and upwards so that the ports on the right side escape their frames.
  18. Asus X501A-RH31 LCD Replacement: stap 18, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 18, afbeelding 2 van 2
    • On the back of the motherboard there are two screws that attach the LCD connector to the motherboard.
    • Unscrew the two screws using the Phillips #00 screwdriver.
    • These screws are 3 mm in length, 3.5 mm in diameter.
    • Pull the connector downwards and out.
  19. Asus X501A-RH31 LCD Replacement, Hinges: stap 19, afbeelding 1 van 1
    • To detach the hinges, use the Phillips #00 screwdriver to unscrew the two top screws on both the left and right hinges.
    • The four screws are all the same. They are 6.2 mm in length, 4 mm in diameter.
  20. Asus X501A-RH31 LCD Replacement: stap 20, afbeelding 1 van 1
    • Once both sides of the laptop are unscrewed, gently pull the upper half of the laptop off of the bottom half.
  21. Asus X501A-RH31 LCD Replacement: stap 21, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 21, afbeelding 2 van 2
    • Use the black plastic spudger to pry off the black squares on the bottom of the laptop screen, this reveals two screws.
    • Take caution when removing these squares as they will bend and crease.
  22. Asus X501A-RH31 LCD Replacement: stap 22, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to unscrew the two screws at the bottom of the laptop screen.
    • The two screws are 6 mm long, 4mm in diameter.
  23. Asus X501A-RH31 LCD Replacement: stap 23, afbeelding 1 van 1
    • Place the black plastic spudger between the top cover of the screen and the bottom of the laptop frame that rests on the table.
    • Push down on the black plastic spudger to pry the top cover off the screen of the laptop.
    • The screen is fragile and too much pressure applied will damage the screen.
  24. Asus X501A-RH31 LCD Replacement: stap 24, afbeelding 1 van 1
    • At the bottom of the screen there are two screws on each hinge.
    • Unscrew the four screws using the Phillips #00 screwdriver.
    • The four screws are 3.5 mm long, 4.5 mm in diameter.
  25. Asus X501A-RH31 LCD Replacement: stap 25, afbeelding 1 van 2 Asus X501A-RH31 LCD Replacement: stap 25, afbeelding 2 van 2
    • At the top of the screen there are two screws on the left side and two screws on the right side of the laptop.
    • Using the Phillips head #00 screwdriver, unscrew the inside screw and then the outside screw.
    • All four screws are the same size. They are 4 mm in length, 4.2 mm in diameter.
  26. Asus X501A-RH31 LCD Replacement, LCD: stap 26, afbeelding 1 van 1
    • Lift the screen up off the back panel enough to have access to the LCD cable connector, but not all the way.
    • Pull the cable gently down and out of the connector to disconnect it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Romana Hruby
596 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G3, Bailey Fall 2017
UMASSD-BAILEY-F17S3G3
3 Leden
8 handleidingen geschreven
Één opmerking
Awesome write up. Thanks a bunch!
Couple amendments based off of my experience:
Step 12: There may be more screws on the far right side of the motherboard
Step 23: You have to split the plastic hinge protrusions to get the bezel off
Marius Lukosevicius - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 786
