Ga door naar hoofdinhoud
Asus X501A-RH31 Keyboard Replacement
Wat je nodig hebt
  1. Asus X501A-RH31 Keyboard  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Keyboard  Replacement: stap 2, afbeelding 1 van 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Keyboard  Replacement: stap 3, afbeelding 1 van 2 Asus X501A-RH31 Keyboard  Replacement: stap 3, afbeelding 2 van 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Keyboard  Replacement, Keyboard: stap 4, afbeelding 1 van 2 Asus X501A-RH31 Keyboard  Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Keyboard  Replacement: stap 5, afbeelding 1 van 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Keyboard  Replacement: stap 6, afbeelding 1 van 2 Asus X501A-RH31 Keyboard  Replacement: stap 6, afbeelding 2 van 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Keyboard  Replacement: stap 7, afbeelding 1 van 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Keyboard  Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Romana Hruby
596 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G3, Bailey Fall 2017
UMASSD-BAILEY-F17S3G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,206
