Ga door naar hoofdinhoud
Asus X200MA Wireless Card Replacement
Wat je nodig hebt
  1. Asus X200MA Wireless Card Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 1
    • Take gold cap that connects to a black wire off using the metal spudger.
  5. Asus X200MA Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the following two screws:
    • Two 4 mm screws using Phillips #0 screwdriver.
  6. Asus X200MA Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Slide the component up and out.
Conclusie
Vanessa Garcia
1.796 Reputatie
6 handleidingen geschreven
Cal Poly, Team 21-24, Maness Winter 2015 Lid van Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Leden
8 handleidingen geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 4,111
