Ga door naar hoofdinhoud
Asus X200MA Speaker Replacement
Wat je nodig hebt
  1. Asus X200MA Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Speaker Replacement: stap 2, afbeelding 1 van 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Speaker Replacement, Speaker: stap 4, afbeelding 1 van 1
    • Disconnect the gold cap that connects to a black wire using the metal spudger.
  5. Asus X200MA Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the plastic component from the clip by gently pulling it back.
  6. Asus X200MA Speaker Replacement: stap 6, afbeelding 1 van 2 Asus X200MA Speaker Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to free the speaker from the plastic clips.
    • Use a finger to lift the speaker and break the bond between the adhesive on the base plate and the speaker.
  7. Asus X200MA Speaker Replacement: stap 7, afbeelding 1 van 3 Asus X200MA Speaker Replacement: stap 7, afbeelding 2 van 3 Asus X200MA Speaker Replacement: stap 7, afbeelding 3 van 3
    • Use the tweezers to carefully lift the wires from the plastic clips.
  8. Asus X200MA Speaker Replacement: stap 8, afbeelding 1 van 2 Asus X200MA Speaker Replacement: stap 8, afbeelding 2 van 2
    • Use the metal tweezers to free the speaker from the plastic clips.
    • Use the metal spudger to break the bond between the base plate adhesive and the speaker.
    • Lift the speakers and remove them from the base plate.
Conclusie
To reassemble your device, follow these instructions in reverse [#|order].
Alli Krininger
391 Reputatie
3 handleidingen geschreven
IUPUI, Team S2-G4, Stella Fall 2019 Lid van IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 562
