Ga door naar hoofdinhoud
Asus X200MA Motherboard Replacement
Wat je nodig hebt
  1. Asus X200MA Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Motherboard Replacement, Battery: stap 4, afbeelding 1 van 1
  5. Asus X200MA Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Slide the battery up and out.
  9. Asus X200MA Motherboard Replacement, Fan: stap 9, afbeelding 1 van 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  10. Asus X200MA Motherboard Replacement: stap 10, afbeelding 1 van 2 Asus X200MA Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Unplug the set of wires located at bottom corner on fan.
  11. Asus X200MA Motherboard Replacement: stap 11, afbeelding 1 van 2 Asus X200MA Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Lift up and out to completely the remove fan component.
  12. Asus X200MA Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 1
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  13. Asus X200MA Motherboard Replacement: stap 13, afbeelding 1 van 2 Asus X200MA Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Pull back the blue ribbon, freeing it from the latch.
  14. Asus X200MA Motherboard Replacement: stap 14, afbeelding 1 van 3 Asus X200MA Motherboard Replacement: stap 14, afbeelding 2 van 3 Asus X200MA Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
Conclusie
Alli Krininger
391 Reputatie
3 handleidingen geschreven
IUPUI, Team S2-G4, Stella Fall 2019 Lid van IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,240
