Ga door naar hoofdinhoud
Asus X200MA Hard Drive Replacement
Wat je nodig hebt
  1. Asus X200MA Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Remove the black foam and adhesive located on top of the hard drive.
  5. Asus X200MA Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  6. Asus X200MA Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Slide out the hard drive
Conclusie
3 andere personen hebben deze handleiding voltooid.
Vanessa Garcia
1.796 Reputatie
6 handleidingen geschreven
Cal Poly, Team 21-24, Maness Winter 2015 Lid van Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Leden
8 handleidingen geschreven
2 opmerkingen
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Antwoord
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 9,466
