Ga door naar hoofdinhoud
Asus X200CA Motherboard and RAM Replacement
Wat je nodig hebt
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: stap 1, afbeelding 1 van 2 Asus X200CA Motherboard and RAM Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: stap 2, afbeelding 1 van 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: stap 3, afbeelding 1 van 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: stap 4, afbeelding 1 van 1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: stap 5, afbeelding 1 van 2 Asus X200CA Motherboard and RAM Replacement: stap 5, afbeelding 2 van 2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: stap 6, afbeelding 1 van 2 Asus X200CA Motherboard and RAM Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: stap 7, afbeelding 1 van 2 Asus X200CA Motherboard and RAM Replacement: stap 7, afbeelding 2 van 2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: stap 8, afbeelding 1 van 1
    • Lift the motherboard/RAM out from the frame.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Jacqueline Collier
1.101 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Fall 2017 Lid van USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 44
Altijd: 9,424
