Ga door naar hoofdinhoud
Asus X200CA Battery Replacement
Wat je nodig hebt
  1. Asus X200CA Battery Replacement, Keyboard: stap 1, afbeelding 1 van 2 Asus X200CA Battery Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Battery Replacement: stap 2, afbeelding 1 van 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Battery Replacement: stap 3, afbeelding 1 van 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Asus X200CA Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
  5. Asus X200CA Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery by the tab you removed the screw from.
    • Replace with the new battery, if necessary.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Jacqueline Collier
1.101 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G2, Leahy Fall 2017 Lid van USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 7,074
