Ga door naar hoofdinhoud
Asus W2W-A1 Keyboard Replacement
Wat je nodig hebt
  1. Asus W2W-A1 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Asus W2W-A1 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Asus W2W-A1 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Keyboard Replacement: stap 4, afbeelding 1 van 2 Asus W2W-A1 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
Conclusie
Joe Redfearn
97 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-29, Maness Spring 2014 Lid van Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 258
