Ga door naar hoofdinhoud
Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement
Wat je nodig hebt
  1. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 2, afbeelding 1 van 2 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 3, afbeelding 1 van 3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 3, afbeelding 2 van 3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 3, afbeelding 3 van 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 4, afbeelding 1 van 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Wifi card: stap 5, afbeelding 1 van 3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Wifi card: stap 5, afbeelding 2 van 3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement, Wifi card: stap 5, afbeelding 3 van 3
    • Unplug the two small cords connected to the wifi card.
  6. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #1 Screwdriver unscrew the 2 mm screw holding the wifi card in place.
  7. Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 7, afbeelding 1 van 3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 7, afbeelding 2 van 3 Asus Vivobook Q301LA-BHI5T02 Wifi card Replacement: stap 7, afbeelding 3 van 3
    • Unplug the Wi-Fi card from the motherboard and remove it from the device.
Conclusie
Jorge Villarreal
397 Reputatie
3 handleidingen geschreven
USF Tampa, Team S10-G3, Thompson Fall 2017 Lid van USF Tampa, Team S10-G3, Thompson Fall 2017
USFT-THOMPSON-F17S10G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 1,524
