Inleiding
If your track pad has become unresponsive, it may be time to replace it. This guide will show you how to replace your track pad.
Wat je nodig hebt
Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
Remove the four 4.0 mm Phillips #1 screws shown.
Remove the two 5.0 mm Phillips #1 screws shown.
Remove the three 3.0 mm Phillips #1 screws shown.
Remove the four 2.0 mm Phillips #1 screws holding the track pad in place.
