Ga door naar hoofdinhoud
Asus Vivobook Max X541SA-PD0703X CD drive Replacement
Wat je nodig hebt
  1. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 3, afbeelding 1 van 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 3, afbeelding 2 van 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 4, afbeelding 1 van 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 4, afbeelding 2 van 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 4, afbeelding 3 van 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 6, afbeelding 1 van 2 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 6, afbeelding 2 van 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Disc Drive: stap 8, afbeelding 1 van 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
Conclusie
Mayar Eskandarani
385 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G4, Cagle Spring 2018 Lid van USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 757
