Ga door naar hoofdinhoud
Asus Vivobook Max X541SA-PD0703X Battery Replacement
Wat je nodig hebt
  1. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 3, afbeelding 1 van 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 3, afbeelding 2 van 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 4, afbeelding 1 van 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 4, afbeelding 2 van 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 4, afbeelding 3 van 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 6, afbeelding 1 van 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 6, afbeelding 2 van 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Disc Drive: stap 8, afbeelding 1 van 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: stap 9, afbeelding 1 van 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: stap 9, afbeelding 2 van 2
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 10, afbeelding 1 van 1
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 11, afbeelding 1 van 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 11, afbeelding 2 van 2
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 12, afbeelding 1 van 1
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 13, afbeelding 1 van 1
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 14, afbeelding 1 van 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 14, afbeelding 2 van 2
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 15, afbeelding 1 van 1
    • Pull the motherboard to the right and lift up.
  16. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Battery: stap 16, afbeelding 1 van 1
    • Remove the 6mm Phillips #0 screw from the battery bracket.
  17. Asus Vivobook Max X541SA-PD0703X Battery Replacement: stap 17, afbeelding 1 van 1
    • Use a plastic opening tool to remove the battery from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Hetvi Mehta
781 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G4, Cagle Spring 2018 Lid van USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Leden
7 handleidingen geschreven
4 opmerkingen
Finished so simple, guide was easy to follow. Thank you
Forever R Holdings - Antwoord
Who was the idiot who designed this laptop? Remove the motherboard to replace the battery? Unbelievable.
Greg Worrel - Antwoord
I have a dead cmos battery and it seems i need to replace the whole battery
Wint3r xxx -
Sir how do I replace my cmos battery? Is it integrated with the battery. I also have Asus Vivobook Max X541SA-PD0703X
Wint3r xxx - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 5,067
