Ga door naar hoofdinhoud
Asus Vivobook Flip 14 TP410U LCD Assembly Replacement
Wat je nodig hebt
  1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement, LCD Assembly: stap 1, afbeelding 1 van 1
    • Turn off the power and disconnected the AC cable from the laptop.
  2. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: stap 2, afbeelding 1 van 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the rubber covers for the two screws located at the bottom of the screen.
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws outlined in the image.
  3. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: stap 3, afbeelding 1 van 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: stap 3, afbeelding 2 van 2
    • Excessive force may cause damage to connections.
    • Rotate the screen 360 degrees for ease of access.
    • Place the opening tool at the corner of where the screen meets the base of the laptop.
    • Pry open the screen along the edge until it is completely off the front cover.
    • Disconnect each appropriate connector while opening up the laptop.
  4. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: stap 4, afbeelding 1 van 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: stap 4, afbeelding 2 van 2
    • Excessive force should avoided since damage may accrue.
    • Remove the cable that connects to the touch display, front camera, and motherboard.
    • Remove each piece of tape that holds down each cable.
  5. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: stap 5, afbeelding 1 van 1
    • Have the new LCD display fully unboxed and ready to be used.
    • Remove the old LCD display.
    • The touch screen sensor is extremely fragile, make sure to not put excessive force on the cable while assembling.
Conclusie
Dominic Bento
326 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 901
