Ga door naar hoofdinhoud
Asus VivoTab Note 8 DC Board Replacement
Wat je nodig hebt
  1. Asus VivoTab Note 8 DC Board Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. Asus VivoTab Note 8 DC Board Replacement: stap 2, afbeelding 1 van 2 Asus VivoTab Note 8 DC Board Replacement: stap 2, afbeelding 2 van 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. Asus VivoTab Note 8 DC Board Replacement: stap 3, afbeelding 1 van 1
    • After pulling the panel off, put it to the side.
  4. Asus VivoTab Note 8 DC Board Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Unplug the battery from the motherboard.
    • Lodge something (a fingernail works fine) under the connecting piece and apply a force straight up and perpendicular to the back of the device.
  5. Asus VivoTab Note 8 DC Board Replacement: stap 5, afbeelding 1 van 1
    • Remove the screws from the black plastic restraint restricting the motherboard's movement using a Phillips #000 screwdriver.
    • Gently remove the black plastic restraint from the motherboard.
  6. Asus VivoTab Note 8 DC Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the six screws holding the motherboard in place using a Phillips #000 screwdriver.
  7. Asus VivoTab Note 8 DC Board Replacement: stap 7, afbeelding 1 van 1
    • Gently pull out the remaining ribbons and cords still plugged into the motherboard.
    • Remove the motherboard from the device.
  8. Asus VivoTab Note 8 DC Board Replacement, DC Board: stap 8, afbeelding 1 van 2 Asus VivoTab Note 8 DC Board Replacement, DC Board: stap 8, afbeelding 2 van 2
    • Remove the two Phillips #000 screws holding the board down.
  9. Asus VivoTab Note 8 DC Board Replacement: stap 9, afbeelding 1 van 1
    • Pull the board up using the opening tool.
  10. Asus VivoTab Note 8 DC Board Replacement: stap 10, afbeelding 1 van 2 Asus VivoTab Note 8 DC Board Replacement: stap 10, afbeelding 2 van 2
    • Pull the DC board away while holding the ribbon cable.
Conclusie
Ryan Spencer
753 Reputatie
6 handleidingen geschreven
Één opmerking
Do you know where to buy the board online? I can't seem to find it anywhere
Chuo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 922
