Ga door naar hoofdinhoud
Asus VivoTab Note 8 Back Panel Replacement
Wat je nodig hebt
  1. Asus VivoTab Note 8 Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. Asus VivoTab Note 8 Back Panel Replacement: stap 2, afbeelding 1 van 2 Asus VivoTab Note 8 Back Panel Replacement: stap 2, afbeelding 2 van 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. Asus VivoTab Note 8 Back Panel Replacement: stap 3, afbeelding 1 van 1
    • After pulling the panel off, put it to the side.
Conclusie
Ryan Spencer
753 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 507
